E36 Air Flow Meter fitted on 325i/2.7i
--alpina--
Post Tue Aug 15, 2006 11:15 pm
Hi guys just a quick one, ive heard that fitting an E36 airflow meter to the E30 325i/2.7i is a good upgrade, now alot of people said yess. but one problem, my airflow meter connector is square but on the E36 aiflow meter connector is round, what can be done for this modification??
If anyone has tried it, let us know and am interested specially how to convert the plugs........
Regards
Jimi
kam-325i
Post Tue Aug 15, 2006 11:30 pm
More than just changing plugs is involved...............
Have a look about for "MAF Conversion", then get your wallet out..........
reggid
Post Wed Aug 16, 2006 4:00 am
if someone made a reasonably priced kit (read not US1000 like the split second kit) i'd be up for it. Its probably more economical to go MAP using standalone ATM.
M5pilot
Post Wed Aug 16, 2006 9:09 am
The MAF conversion is very expensive.
Whether it's worth it is a different matter but it certainly does make a big difference over the AFM.
Stand alone ECU's are getting very cheap now.
Throttle response with no AFM or MAF is truly amazing. You can floor the throttle as quick as you want and the response is immediate.
Sal
Ant
Retired Team Member
Retired Team Member
Post Wed Aug 16, 2006 11:46 am
Another vote for a standalone here....
M5pilot
Post Wed Aug 16, 2006 11:50 am
If mapped carefully stand alone can also return some excellent fuel consumption on cruising.
The Alpina returns unbelievable MPG on cruising.
If you want to keep your M20 and get the most out of it Stand Alone is the way forward.
I cannot stress how much difference it makes.
Sal
reggid
Post Thu Aug 17, 2006 3:39 am
what standalones are recommended
