i need a favour !?
glenn
Engine Transplant Services
Post Sat Mar 12, 2005 7:59 pm
can someone with a m3, please measure the full width of the rear axle for me (pretty please).
i can then compare the width with the e36 evo axle i have here.
there's no urgency, just next time one of you guys have got both of the back wheels off
(p.s. need it measured with out the wheels on)
thanks in advance.
glenn :wink:
Turbo-Brown
Boost Junkie
Post Sun Mar 13, 2005 8:00 pm
If no one can help with this one, might be worth asking your freindly local dealer.
Failing that, if you call Barons BMW in Ash Vale and ask for a chap called Steve Ticknell, he's the most unbelievably helpful techy person there and he might be willing to help.
He pointed me in the right direction when I was trying to get my 3.2L M3 engine going outside of it's native environment :)
Good luck!
EDIT> might be Simon Ticknell thinking about it. Ask whoever answers the phone I guess, his surname's definately Ticknell :)
Post Sun Mar 13, 2005 8:06 pm
i go to barons all the time for "bit 'n bobs" in the parts department!
Kelson
Post Mon Mar 14, 2005 1:38 pm
Doing some work on mine this week end so if you still need this info, I can get it for you for Monday 21 Mar 2005 :roll:
Goes ok!
glenn
Post Mon Mar 14, 2005 3:26 pm
thanks you gents for the help,
kelson, next weekend will be fine, it will be a few weeks yet before i'm
ready to mount the axle,
so theres no rush just yet.
turbo brown, simon 13,
thanks for the info,
i'm sure i'll be needing some technical help during this project,
nice to know there will be someone who might beable to help.
thanks again
glenn
:cheers:
:cheers:
:cheers:
Kelson
Post Mon Apr 04, 2005 10:14 am
Glenn
Had the rears off this week end to clean inside them, check brakes etc. Measured across the axle, wheel mounting flange to wheel mounting flange with the car supported on axle stands at the beam ends.
I used two steel rules and measured as close to the axle line as possible below and to the rear of the diff at about the 4 oclock position looking from the left of the car towards the right, in a straight line between the two steel rules parallel to the floor (phew). The measurement I got was 1451mm. You will need to allow a bit of variation to allow for camber variation etc but hopefully this will be close enough.
Kelson
Goes ok!
glenn
Post Mon Apr 04, 2005 2:24 pm
thanks kelson,
your a gent :D
