ignition barrel
jordano
Hi Guys anyone know how to remove the ignition barrel have got a new one with keys but dont know where to start lost without my wheels.
Ant
- Retired Team Member
do you still have the key for the old one dude ?
if so remove the old by putting the key in P1 and insert a small allen key into the hole in the chrome section around the barrel, wiggle it and it will eventually come out.
new fitting is key in p1, push key/barrel into hole, remove key and thats that, holds itself in place.
HTH
HTH
Email FTW
jordano
Thanks for that Ant saved my life hope it goes as easy as yuo put it J
Ant
its a right PITA, no real technique just use a 1.5mm allen key and wiggle/waggle/prod/poke and she'll come away eventually.
I hate doing these, e36 are worse as they keys normally worn to hell too
Email FTW
