I dont seem to have any hazzards anymore.
Have indicators so could it be a relay or is there a seperate fuse for te hazzards as well
No hazzads
Richy325iTouring
Demlotcrew
try the switch it self.
Andrew
Andrew
Richy325iTouring
tried with one i know is working and still nothing.
Demlotcrew
the relay? its under the steering column
Richy325iTouring
Chears Got to dig out my spare now wherever that is
nadz325i
i had this on my sport to, if your indicators are not working to its probs a dry joint on the relay like andrew said on the stearing column.
In answer to one of your original questions - Yes, there is a seperate fuse, No.24, 15A.
Richy325iTouring
Indicators work fine just no hazzards.
i ask about a seperate fuse as other cars i had they share the same fuse.
This is what is confusing me.
will check fuses tomoz and still aint found me other relay. God knows where me spare is gone. Ah well breakers time again
johnono
richy, is this cos u were messin around with the ind. lights and the reverse lights?
Richy325iTouring
nothing to do with that my hazzards havent worked for a cpl weeks
