Cylinder head pressure testing in Cheshire/Manc?
cheesebox
Post Tue Aug 08, 2006 3:07 pm
Anyone know of an outfit who could pressure test my M42 head? The nearer to Sale, Manchester or Buxton the better!
gazm3
Post Tue Aug 08, 2006 3:12 pm
Princess Engineering are very good in Manchester off the A6.
You near Sale mate, I live up the road.
Im sure Chris-W will know someone near to Buxton.
cheesebox
Post Tue Aug 08, 2006 3:46 pm
Cheers mate, will check them out. I work in Sale by the fire station... not seen your cab around - looks well nice. Where's Chris-W?
Chris-W
Post Tue Aug 08, 2006 3:48 pm
The place I use is in Crewe if that's any use to you. Never used anyone over the new-money-footballer side of Cheshire :)
Templ8e30
Post Tue Aug 08, 2006 10:52 pm
I use Impulse Developments in Rochdale, it's a bit of a trek for you but their work is top notch.
http://www.impulsedevelopments.co.uk/
Cheers,
Iain T
2007 Mazda 6 2.0 estate
gazm3
Post Wed Aug 09, 2006 10:02 am
Princess Engineering Auto Company Ltd.
Pear Tree Garage
161 Barlow Rd
Levenshulme
0161 224 2664
I found there card. I have used them and they are normally very busy.
cheesebox
Post Sat Aug 12, 2006 10:48 am
Brilliant thanks guys.
Can you advise, will I need to remove the camshafts and valves?
cheesebox
Post Tue Aug 15, 2006 1:05 pm
Right, even better I just found this top bloke right round the corner from where I work. He does work for a lot of garages in the area including Williams BMW. He even has some Boeing 747 wheels in for bearing re-fitting! Sounds like he'll repair pretty much anything (not interested in port/polich though - too time consuming). He was recommended by Eddie at Cross Street Garage.
He's removing the camshafts and valves, pressure testing and will skim if necessary, check valves and decoke, and reassemble with new stem seals. (Assuming it passes the pressure test!) . As a guide, pressure test alone is £35.
Details:
Peter
WES Engineering Services
07986 704859
Just off Washway Road in Sale by a road called Oakfield, opposite the Vine pub.
Will let you know the results...
