My wipers sit really high on my dash and its bloody annying as it covers up my left nearside wing/bonnet area.My brothers on his IS sit right down so they are basically as far down (In the off position) as they can go, touching the black window trim on the screen.Mine are about 2 inches above the bottom of the windscreen, how do these come off?I was thinking maybe theres a cog or somthing they push onto and therefore you can take them off and reset them if you like. (Like the steering wheel mount thingy, the wheel can be taken off and put in any position, then tightened up)
Cheers guys
How do the wipers come off?
SwirlyE30
1986 Chevrolet Corvette. 330ftlb torque....V8s rule!
glenn
- Engine Transplant Services
at the bottom of the wiper arm there should be a plastic cover, lift it up and you will see a 13mm nut, undo it , pull the arm off and replace the arm in the position you want it.
it may feel like its siezed on, but just move the arm slightly, and it should free itself.
its on tapered splines.
hope this helps.
glenn
hope this helps.
glenn
SwirlyE30
Nice one mate, cheers.Done it now, finnaly i can see over my wipers!!
