Thermostat
stevetigger
Post Mon Aug 07, 2006 12:01 am
Is mine broken?
When car warms up, the top rad hose is warm and the bottom one is cold!
cliffybabe
Powered by Nelly
Powered by Nelly
Post Mon Aug 07, 2006 12:07 am
stevetigger wrote:Is mine broken?
I think thats how mine is mate, and i have just had a new thermostat
stevetigger
Post Mon Aug 07, 2006 12:17 am
That sounds good! :cool:
Post Mon Aug 07, 2006 9:36 am
Shows the rads doing its job then! What were you expecting?
stevetigger
Post Mon Aug 07, 2006 10:37 am
Silly me, I was expecting all the pipes to be warm :mad:
All good then, shows that the little 318i rad does the job well in an M50 engined E30
Bob_S
Post Mon Aug 07, 2006 5:22 pm
why not upgrade the rad to the 520 or 525 one like in the IS?
Bollocks to this 24v scrap!
stevieg
Post Mon Aug 07, 2006 7:26 pm
Mine was the same and also running cool,i inspected the thermostat and it had broke,one of the metal arms holding the spring in place had snapped so water was just running through with no restriction,one new thermostat later and the bottom hose was getting hot and temp gauge was spot on,just under halfway.They system can also be a bugger to bleed,i found the best method was to disconnect the top hose from the rad and pour the water straight in from there,it runs past the pump and fills the rad up from the bottom,eventually the water will run out of the top of rad,reconnect the hose and top up the expansion tank,then run the car with the bleed screw (next to the expansion tank cap) unscrewed until all the air hisses out and you get a steady stream of water,job done.
Post Mon Aug 07, 2006 9:20 pm
stevieg wrote:,i inspected the thermostat and it had broke,one of the metal arms holding the spring in place had snapped
Very common. I would go so far as to say that MOST original BMW thermostats end up this way.
