1) The tappets are noisy. Are they adjustable?
2) Idle is rough. Fine when driving, but idle is lumpy.
I've changed the Dizzy Cap (£75) Rotor Arm (£23), plugs and air filter but this has made no difference even though the parts I replaced were absolutely knackered... so that's £140 wasted so far.
Is a dirty ICV a common problem and causes the lumpy idle? There are no air leaks in any of the inlet piping... no leaking manifold either inlet or exhaust. Could it be faulty leads? I don't think it is...
Anyone who has knowledge of the M40.. please advise me.
Also, on one of the plug leads there's a collar with another lead attached that dissappears down the front of the block. What's this for? I might have damaged that while changing the Cap... though it's made no difference to the running of the car.
AND... last one I promise... the rev counter doesn't work. Where is the feed for this?
God... I feel like a right Noob!
Thanks,
Giles.
