No front fog lights
eldarvanyar
Post Thu Aug 03, 2006 3:06 pm
The front fogs on my 1990 320i SE are not working.
Any ideas, ie. fuse, switch, wiring etc
I will take a look once I have some ideas
Thanks zoners
8O
eko
Old timer
Post Thu Aug 03, 2006 3:09 pm
K8 relay and fuses 29 and 30(?) are for the fogs,first things id check,then bulbs!
Is the green light coming on in the car?
fazgti
Post Thu Aug 03, 2006 5:08 pm
funny you should mention this cause mine aint working either, the lights dont even illuminate on the dash
cliffybabe
Powered by Nelly
Powered by Nelly
Post Thu Aug 03, 2006 5:14 pm
Mine was a busted switch
stuartgallafant
Post Thu Aug 03, 2006 7:09 pm
you are a busted switch!!
eldarvanyar
Post Thu Aug 03, 2006 10:45 pm
thanks chaps I will take a look tomorrow
The green light is not coming on in the car
:mad:
Morat
Post Fri Aug 04, 2006 12:09 am
try fiddling with the switch, holding it half in/half out and moving it slowly from fully in to fully out. I had this problem on my last E30 and it was the switch itself.
eldarvanyar
Post Mon Aug 07, 2006 9:23 pm
I have tried holding the switch in and out and wiggles it a bit and the lights come on. Looks like the switch will have to get a replacement. Thanks for your help everyone.
Post Mon Aug 07, 2006 9:31 pm
My '88 325iSE had non-working front fogs. Replacing both bulbs (much cheaper to buy in France, BTW!) and cleaning out the switch contacts (fairly easy to do - the switch just prizes apart with a thin screwdriver) sorted them.
Post Mon Aug 07, 2006 11:56 pm
Switches usually respond well to dismantling, cleaning and lubricating.
Post Thu Aug 10, 2006 9:25 pm
What do you use to lubricate them? KY or Vas... winkeye
