Fitting M3 bush to a non M3.
Jamjon101
Post Wed Aug 02, 2006 10:09 pm
Hello you lot,
Gonna order myself a set of powerflex bushes for the car and was wondering is there any problems when fitting the eccentric control arm bushes to an non M3? Or should i order the fixed type?
Cheers.
Jam.
Post Wed Aug 02, 2006 11:17 pm
Shouldn't be any problems, although the tracking will need checking/resetting, as it will after any front suspension work.
Jos
Post Wed Aug 02, 2006 11:25 pm
Whats the advantage of the offset front bushes? It's not as if camber is an issue on the fronts.. just wondering what it changes.
'94 e36 tree climber
Post Wed Aug 02, 2006 11:41 pm
castor
gareth
Post Thu Aug 03, 2006 6:45 pm
it also shortens the wheelbase a bit.
Demlotcrew
Post Thu Aug 03, 2006 6:55 pm
Nope, it makes the wheel base longer.
Andrew
gareth
Post Thu Aug 03, 2006 8:07 pm
durr... :mad:
what my brain was thinking and what my fingers were typing were two seperate things for a minute!!! :D
positive castor (moving the bottom of the strut forward) = heavier steering but with better turn-in. also more self centering.
