Want to fit an Oil Pressure guage to my touring, but where would the pressure sender fit? Engine is the 2.5 M20.
Oil pressure guage
jmc330i
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Turbo-Brown
- Boost Junkie
I fitted mine to the same hole as the oil pressure switch.
It's about 1/3 of the way back along the block on the drivers side probably 2" above the sump.
The thread's an M12x1.5 which is a bit of a funny size unfortunately
jmc330i
So you did away with the pressure switch?
Any suggestions on which sender to go for?
James
'91 325i Sport
'91 325i Sport
Turbo-Brown
- Boost Junkie
In my case I was rigging up oil supplies to the turbos so I machined up a block of ali with 4 outlets on it:
1 to the oil pressure gauge which I plumbed in using copper brake pipe and fittings (M10x1)
2 to the turbos, again in copper with brake line fittings
1 to the original oil pressure switch with the M12x1.5 thread.
I've got a mechanical oil pressure gauge so it didn't really have a sender as such.
jmc330i
Sounds like a plan. Im sure I can get something sorted along those lines to have both
James
'91 325i Sport
'91 325i Sport
Jon_Bmw
- Dangerous when thinking
The other way is drilling and tapping into the oil filter housing, but personally I would go with a T piece adapter like Mr brown said, then retaining your oil pressure switch and gaining the gauge.
jmc330i
What, where the oil cooler pipes fit? I dont have that bit on my 2.5 - was removed and Im not running the cooler.Jon_Bmw wrote:The other way is drilling and tapping into the oil filter housing.
James
'91 325i Sport
'91 325i Sport
Jon_Bmw
Yeah that bitjmc330i wrote:What, where the oil cooler pipes fit? I dont have that bit on my 2.5 - was removed and Im not running the cooler.Jon_Bmw wrote:The other way is drilling and tapping into the oil filter housing.
Looks like the oil pressure switch location then
