MikeeMiracle
Post
Mon Jul 31, 2006 12:04 pm
Just got a set of 14's for track work and 15's for road use. Im looking at rubber for them but all the top tyre's im familiar with are not available in these smaller sizes.
I find myself heading down twisty country roads quite frequently so im looking for performance rubber. Can you guys recomend some suitable tyre's?
Currently looking at Toyo T1R's for 15's and Yoko A539's for the 14's.
Red 318is
Take me to the land of the twisty's
320Touring
Post
Mon Jul 31, 2006 12:06 pm
the toyo's are excellent in the 15's either the T1R or T1S are great
Steviec
Post
Mon Jul 31, 2006 12:13 pm
My fave tyres for price and performance are Kuhmo Ecsta (sp?), ive had them on my last 3 cars.
handpaper
Post
Mon Jul 31, 2006 1:04 pm
Another vote here for the Toyo T1-Rs, excellent on the road, good for shorter sessions on the track (overheated after 4 laps of the 'Ring)
As for track tyres, maybe these?
http://www.camskill.co.uk/products.php? ... 9s702p3836
Camskill's have good prices on the road tyres, too.
Edited for wrong size tyre
MikeeMiracle
Post
Mon Jul 31, 2006 2:18 pm
Might go for the R888's ultimately. My mate recons putting 14" wheels on will bugger the handling so I was possibly thinking of just using the 14's I have for looning around. Thing is, I swear my car came with 14's anyway so I don't see hwo fitting the same size tyre will bugger the handling.
Red 318is
A1BMW325iSport
Post
Mon Jul 31, 2006 2:35 pm
toyo t1 or b f goodrich profiler g
dazleeds
- old skool raver
handpaper
Post
Mon Jul 31, 2006 11:32 pm
Keep the rolling radius the same and geometry won't be affected. I did notice a difference going from 14" BBS > 15" BBS on mine, mainly because the lower profile tyre flexed less on the sidewall. The overall size of the wheel+tyre stayed about the same (about 23.5" diameter). This changed when I fitted 50-profile tyres later on, tightening up the car even more, but losing just under an inch of tyre+wheel diameter (the speedo now reads another 3% over).
The only worry I would have using 14" wheels on the track would be the possibility of rolling the 60-profile tyres off the rims. They look awfully tall to me.
But I expect Toyo know what they're doing
stuartgallafant
Post
Mon Jul 31, 2006 11:56 pm
as steviec says, the Kumho Ecstas are a good choice and i've used them quite often. although i've just changed to a Goodyear Eagle F1 setup on the front and Kingstar K106's on the rear, and CANNOT fault these tyres! amazing, wet and dry! the tread pattern is brilliant and really does work. and they have quite a good wear life too
- Homo Hair
Post
Tue Aug 01, 2006 2:18 am
Toyo Proxes T1-R's
Run 205/55 rear and 205/50 front i reckon to tighten response
Alean_Mofo
Post
Tue Aug 01, 2006 10:02 am
MikeeMiracle wrote:Might go for the R888's ultimately. My mate recons putting 14" wheels on will bugger the handling so I was possibly thinking of just using the 14's I have for looning around. Thing is, I swear my car came with 14's anyway so I don't see hwo fitting the same size tyre will bugger the handling.
Because as was rightly said, they will flex alot more due to the taller sidewall, and also they are 14" bottletops, not BBS's, so will probably weigh more than your Alpina reps!
- Homo Hair
Post
Tue Aug 01, 2006 10:40 am
iS' came with 14" BBS as standard
Bottlecaps wont weigh more than 17" Reps either
Alean_Mofo
Post
Tue Aug 01, 2006 11:29 am
Jhonno wrote:iS' came with 14" BBS as standard
iS may have come with BBS's, but he's just bought a set of bottlecaps!
I thought bottlecaps were steel? Are the reps really heavy or what?
swindy
Post
Tue Aug 01, 2006 1:54 pm
I have shopped about for tyres and honestly found a site that can deal any size and most makes including toyos its
www.mytyres.co.uk deliver straight top your door then find a fitter that will do them, I use National as a back hander ten quid a tyre fitted and balanced, a rough idea local tyre shop to sell and fit toyo t1r is over £80 for 205/50/15 from the web same tyre £43 and tenner fitting saved £27 quid time that four times...... Cheaper over the internet.
Mark.
"We aint here for a long time, we're here for a good time."
"Don't take life too seriously, you'll never get out alive."
Morat
Post
Tue Aug 01, 2006 2:06 pm
I don't think bottletops are steel, mine seem to do the flaky thing just like normal alloys!
- Homo Hair
Post
Tue Aug 01, 2006 7:03 pm
Alean_Mofo wrote:Jhonno wrote:iS' came with 14" BBS as standard
no bottlecaps are ali still..
Alean_Mofo
Post
Tue Aug 01, 2006 7:12 pm
Thanks Jhonno for putting me straight
Still not sure about them as a track day wheel though.......
TheDutch
Post
Tue Aug 01, 2006 8:04 pm
Standard wheels were steels with iS specific hub caps, alloys were an optional extra.
