speedo pissing around
Brenner5
Post Sun Jul 30, 2006 8:52 pm
i got a very annoying problem with my speedo
everytime i accelerate the speedo needle dies not giving me a reading. as soon as i let go of the accelerator the needle comes back to life and gives me a reading
has anyone had this problem or know what the problem is or could be?
cheers
320_Fizz_i
kevin316i
Post Sun Jul 30, 2006 9:45 pm
Probably the connector on the back of the diff, the wire into the connector often breaks so you will get an intermittent signal to the speedo.
visionz
Post Sun Jul 30, 2006 10:56 pm
indeed kevin same thing happened to me.. i just cleaned up the connectors and put them back on.. lube em up with a bit of dubs aswell
Bavarian Motor Works - German Muscle
Turbo-Brown
Boost Junkie
Post Mon Jul 31, 2006 9:00 am
I had exactly the same thing!
Found on mine it was the connections to the speedo dial in the cluster itself that were at fault so every time I accelerated, the inertia of the dial broke the connection, and when I started braking, the momentum remade the connection.
Open up the head and re-flow the solder on the joints in there if the other suggestions don't work :)
