Job done, not that bad.
13mm head bolts hold the UJ assembly on, undo both and wedge the clamps open. Slide the whole assembly further down onto the steering rack splines and the steering box end will come off. Pull it free from the steering rack. If your guibo is riveted on, cut it off before drilling/hacksawing the rivets - it makes clamping the parts in a vice much easier.
Part numbers are:
Guibo (Artic Disc) B32.31.1.153.993 £9.93
Bolt x4 B32.31.1.153.995 £6.32
Nut x4 B07.12.9.946.400 £0.60
+ VAT for all prices
Use the official BMW bolts and nuts. The bolts are machined to precisely fit the UJs and guibo; the nuts are crushed slightly to make them shakeproof and incorporate captive washers. BMW also specify 8 spring washers to go either side of the guibo holes (part number B07.11.9.932.095 ).
Before reinstalling, centre your steering wheel and road wheels and apply the steering lock to keep things still. My steering wheel position now matches my direction for the first time since I bought this car
