Post
Mon Jul 24, 2006 10:03 am
Hi to everyone from Christchurch in New Zealand, well i have the same problem since i lowered the front a fortnight ago,i bought aftermart Dobi springs that dropped the front 35mm, however i did not lower the rear as i like the rake look.I took it for a wheel alignment and the blokes measured from the lip of the guard to the ground and found the left side higher by 15 mm on the rear left side. They suggested that i take it home and swap the left rear over to the right and vice versa and this has done the trick.Good luck from down under and The Rolling Stones are the greatest rock n roll band in the world, Keith is tops.
