Got some noises going on..Bearings? not sure on the BMW setup but had this in the Taxi and it was bearings...lil whining and quiet when engaged.
If its a new clutch kit should i take advantage and uprate it? as im FI now
If so any suggestions which wont hurt the bank or just stick to the standard
Clutch Replacment
Depends how FI'd you are, but standard 325 clutch is fairly generously rated.
JAMZ
Cheers Brian,
Well im only a noobie with the FI setup only running 7psi but will be looking to up that once i get the MS install so wondering if its worth uprating now
