325i engine in the 320!?!?!?!?!?
e30bmlover
Ac Schnitzer prophet
Post Thu Jul 20, 2006 4:31 pm
hi all, im on about buying the 325i (pre facelift engine) for my facelift 320i. got a few questions...
1/ will my radiator/cooling system work with it?
2/ will my obc work with it?(need it cos its saved my ass a few times)
3/ will the downpipes/exhaust work with it?
4/ will the 320 diff be ok?
5/ am i makeing a big fuss over nothing..... is it just plug and play!
any help would be greatly appreciated
Post Thu Jul 20, 2006 4:34 pm
diff might not be up to the job.. its prob a small case..
dazleeds
old skool raver
old skool raver
the only problem i can see is that early 325s use differnt ecu
so youd need to swap that and the engine loom over and maybe a few other parts
im sure someone will know exactly whats needed
obc will need sensors from orig engine
exhaust i think is different
diff nono
www.oldskoolfantasy.co.uk
Post Thu Jul 20, 2006 4:35 pm
better off swapping to the later loom and ecu..
e30bmlover
Post Thu Jul 20, 2006 4:39 pm
how easy is it to swap looms over??? this is getting scary!
jaistanley
Post Thu Jul 20, 2006 4:40 pm
Better off swapping to later engine loom and ecu and getting an early engine whilst you're at it then... Higher compression aren't they?
Jai
Post Thu Jul 20, 2006 11:23 pm
e30bmlover wrote:how easy is it to swap looms over??? this is getting scary!
Easy! Leave them connected to the engines when you swap them.
eamo
Post Thu Jul 20, 2006 11:44 pm
you'll also ned pickup sensor and pulleys from your 320
