My car doesn't switch the interior lights on when either of the front doors are open (opening the rear doors puts the lights on just fine). Also you can't move the electric windows with the key out and the front doors open. Does anyone know what this might be?
Morat
My car doesn't know when its front doors are open...
Morat
Chris-W
The door switches are either knackered or just need a good clean.
A single Phillips screw to take them off.
jcjdavis1
Hi might be a good idea to disconnect bat. or take fuse out incase you blow something when taking switch out.
Chris-W
I think the worst that would happen would be a fuse might blow...
No fuses will blow! All that will happen is the interior lights might flash a bit and a relay at the back of the glovebox might click.
appletree
when i got my car it was the same, the bloke had disable dthe arlam because it was going off all the time, tuned out to be the door switches, took them apart cleand them and know they work fine.
