Gearbox oil rear seal
e21Jason
Post Mon Jul 17, 2006 11:43 pm
Hi
Has any body ever changed the rear oil seal insitu, any advice/tips
Jason
Post Tue Jul 18, 2006 12:31 am
e21Jason wrote:Hi
Jason
Yes. The nut is tight, and needs a thinwall or ground down socket. Put a 22mm spanner on the crank pulley nut with the end jammed against the chassis rail to stop the engine turning, put the gearbox in 5th and hope your clutch is good.
DON'T FORGET TO REMOVE THE SPANNER AFTERWARDS.
Change the gear selector oil seal as well.
e21Jason
Post Tue Jul 18, 2006 7:30 am
I give it a try and let you know how it works
Jason
Post Tue Jul 18, 2006 8:58 am
Are you totaly sure the seal is leaking?
A leak from the selector shaft seal runs down the gearbox onto the output shaft and looks exactly like a leak here.
