removing the cat
DaveD
- E30Zone Wiki Specialist
I am thinking of removing my cat and need to know if, when the oxy sensor is removed, anything else has to be done.
martinclan
I don't think you can just remove the oxy sensor without also changing the ECU. The ECU expects the oxy sender to be there and won't work well without it.
I had a cat on the 325 donor for my Marlin. I removed the cat but kept the the oxy sensor.
Robin
Robin
It's an E30 Jim but not as we know it...
jmc330i
Remove the Cat and leave the O2 sensor in place, will work fine.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
