tyres on an e30.how wide can you go?
technoviolet
as the title says guys,i currently have 205/40/17's on the sport but would 225/45/17's fit without fouling?anyone using 225/45/17 on the pina reps?
johnono
depends on the et? ive seen silli wheels on beemers, like 9.5" 225Ԛ´s or somin like that, not sure if the inner arches were modded though
charlE30
I'm running 215/45/17 on pina reps and get rubbing on full lock but mine has been dropped 60mm
I'm goin fit some M3 offset bushes and 40mm springs to improve it. No probs at all on the back.
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
E30Adam
225/45/17 is the wrong tyre size for 17" Alpina Reps. The correct size is 215/40/17 unless you get a wider wheel. Most people stretch 205's on them without and problems which is what you already have.technoviolet wrote:as the title says guys,i currently have 205/40/17's on the sport but would 225/45/17's fit without fouling?anyone using 225/45/17 on the pina reps?
I just bought some 9" wide 16" rims and have 205/40/16 tyres stretched over the rear wheels and the arches rub. I've ordered some new tyres for the rears which are 225/45/16 and these will rub even worse so I'm going to get some arch work done.
I think anything more than 215 wide on your 17's and you'll run into problems.
