Should I be able to twist this???????
Project_E30
Post Wed Jul 12, 2006 10:02 am
I have a squeaking/clunking noise coming from my drivers side front suspension. In the picture below I can easily rotate item 8 from left to right (twisting). Basically item 10 stays still and item 8 can be rotated from left to right, twisting about it.
But on the passengers side I cannot.
My question is should I be able to do this and could this be the cause of my constant squeak/knock?
Templ8e30
Post Wed Jul 12, 2006 10:26 am
There is a rubber bush cast into the bottom of part number 8 preventing it from being twisted.
You need a new one.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
DaveD
E30Zone Wiki Specialist
Post Wed Jul 12, 2006 10:43 am
i think you can buy a bush at superflex..otherwise its the whole thing £26
http://www.motorsportworld.co.uk/
SPF1862 Superflex Bush(es) Front Anti Roll Bar Link Eye Bush & Stainless Steel Tube (1 of 2)
£8.47
£7.62
Project_E30
Post Wed Jul 12, 2006 1:26 pm
Is this easy to change? Just and unbolt and swap job?
Should I change both sides?
DaveD
Post Wed Jul 12, 2006 4:06 pm
if one has gone the other can't be far behind.......i watched my mechanic just take one off and put the new one on...the arb bushes were a proper swine tho
posted the wrong link before
http://www.superflex.co.uk/SuperFlex_BMW_E30_Prices.pdf
