WHY Does my Back Box hang so low??
cliffybabe
- Powered by Nelly
Ok on my cab i have a standard rear box it seems to hang quite low folwer commented on it a while ago, im now in the process of geting hold of a new sports back box and fitting my mtech 1 kit when it arrives.
Will the mtech 1 kit hide the hang or is there anything i can do to bring the box up more?????
Neil
Neil
cliffybabe
- Powered by Nelly
Here's a pic ali took a few weeks back
MikeeMiracle
Speaking generically, it's normally an problem with the mounting of the zoorst or the mountings themselves. Some cars have rubber "O" rings which hook onto the underside of the car and the zoorst hangs of them. If they are badly worn/sagging the zoorst will also sag/be lower than normal.
Red 318is
Take me to the land of the twisty's
cliffybabe
- Powered by Nelly
its got like a metal cage around the box if u like a metal strap
stevetigger
But they hang of rubber O rings, if they are worn it will sag. Buy new ones!
Dominitry
It shouldnt be that low, you will have 2 metal straps each connected to a rubber suspending thing, not the kinky kind...theyre mine...but check the metal straps are really tight and as mentioned the rubber thingy are not worn, heres a photo of a sports box with a tech 1 kit (i think thats the one your getting?) so you know how it should look..
cliffybabe
- Powered by Nelly
ah im gonna have a look when i pick her up tonightstevetigger wrote:But they hang of rubber O rings, if they are worn it will sag. Buy new ones!
cliffybabe
- Powered by Nelly
Dominitry
cheers for that pic mate
Dominitry
Your very welcome
stevetigger
cliffybabe
- Powered by Nelly
steve thanks mate,
thats solved it mate, i never changed thm when i fitted my back box, im gonna get some new one's for when my new one goe son at the weekend
cheers fellas
cheers fellas
stuartgallafant
cliffybabe
- Powered by Nelly
stu could ya mate please. thanks mate
stuartgallafant
cliffybabe
- Powered by Nelly
quality mate thanks again
cliffybabe
- Powered by Nelly
thats y the zone is so cool, within a hour i had a answer within 2 hours i had th eparts sorted cheers guys thanks Stu for sourcing the bitsstevetigger wrote:Sorted
Thanks again
Neil
GDBN
Makes a big difference ... my old ones were 5 years old and sagging badly.
May I ask if there are any tips on fitting the rubber rings ?
Last time it took me 10 mins with a pair of screwdrivers and a lot of swearing to fit one. There must be a knack where thety just pop on.
And does anyone have a picture of the gearbox mounting bits fitted ?
I can't seem to get the bracket that holds the pipes to match up with the gearbox fitting. (hope that makes sense - doesn't seem to fit as easy as it looks on realoem).
G
G
dazleeds
- old skool raver
bend the prongs on the backbox mout with some pliers
i did same job this afternoon makes it a whole lot easier
www.oldskoolfantasy.co.uk
Martinaston
Did mine ages oga so i'm not sure but i think i rotated them 90 degrees so the thinner bit's were at the sides to make it easier to strech, then got the bracket in and turned it back to the upright position.
As for the gearbox mount, start from the front and work your way back when fitting the exhaust and bolt the carrier to the box first.
It may be worth loosening all the unions off a bit until you get it all together.
stevetigger
or fit the rear box brackets to the rubbers then fit to car, then put back box in bracket!
