Vibration through the steering wheel.
danny_j
Post Fri Jul 07, 2006 9:41 am
I was just wondering is it possible for the wrong size lowering springs to cause vibration through the steering wheel?
It seems ever since i lowered my car (318i) the steering vibrates at around 40-60mph?
Also have what can only be described as "klonking" noises
Its most defientley been lowered properly, but i'v recentley learned there are different size lowering springs??
If i would have used 325 springs would this have an effect in anyway?
georob
Post Fri Jul 07, 2006 9:42 pm
You checked the discs, tie rod ends etc?
massive
Post Fri Jul 07, 2006 9:50 pm
I cant see how springs can cause vibration. The clunking noise could be the hitting of the bump stops. How how have you gone?
JAMZ
Post Fri Jul 07, 2006 9:53 pm
Top mounts checked while you were there?
Adammcf
Post Fri Jul 07, 2006 10:35 pm
Balljoints.
kevin316i
Post Fri Jul 07, 2006 11:51 pm
Are you sure your wheels are properly balanced?
jagtech2002
Post Fri Jul 07, 2006 11:56 pm
check anti roll bar drop links, if these are perished it can be exagerated when the car is lowered. mine did exactly the same after i dropped it 40mm
Martinaston
Post Sat Jul 08, 2006 12:28 am
Are you sure the wheels are seated correctly ?
slideways
Post Sat Jul 08, 2006 12:46 am
my 325 was as quiet until i put in my new h and rs. then thw top mounts started complainig. dont know if it was the disturbiing of them or the difffernt tension of the springs or height changes but once i added new top mpunts all was well,
would also check the drop links as was already mentioned...
