what's a normal battery drain rate with everything off?
Toby_Unna
Boost Junkie
Post Tue Mar 08, 2005 1:50 pm
car keeps flattening battery overnight. battery might possibly be on the way out but i don't think so. alternator is fine.
the current drain once the car has settled for a minute or so is around 90 milliamps i.e. 1/10 of an amp, which seems quite high.
if i pull the radio/interior light/etc fuse (number 21) the drain drops to about 8mA.
do i have a stuck light in the boot or something, or is it normal for the radio to be taking 80mA?
boybimmerm3
Post Tue Mar 08, 2005 9:33 pm
90ma is too high really. should be around 60 max. try disconnecting all consumers one at a time which are on fuse 21 to see what is causing the drain, the glovebox light switch used to cause some problems.
Post Tue Mar 08, 2005 10:45 pm
Even a 5W lamp takes over 400mA, so it's not the boot lamp.
90mA is a bit on the high side, but I woulld just about consider it normal, depending on what equipment you have fitted.
Your battery should be able to cope with a drain of 90mA for weeks without going flat, so the first thing is to get the battery checked out.
Toby_Unna
Boost Junkie
Post Wed Mar 09, 2005 11:37 am
cool, thanks brian.
feeling a bit daft really, i'm supposed to be quite good with electrics! if i'd bothered to read the 55AH on the battery i might have worked out that 0.1A drain is going to take 500 odd hours to flatten it! Doh!
