Electric windows, needs a door open to work???
EOS
Got a bit of a funny one with my electric wondows at the moment, they only work when drivers of passenger door is open, when there closed they won't work and when one of them is opened they do?
First i thought it was that little switch thing but insn't that, then maybe a broken cable in the wiring going to the door, but obviously not the case as the window works with the opposite door open.
Is this a common fault?
Looking at the wiring briefly i can't see anything that should cause this to happen.
RevBillyG
Assuming you mean when the ignition is turned off. It's supposed to do that. Took me about 3years to work it out
Best smiley ever----->
fowler
- Boost Junkie
with ignition on or off ??????
EX A-Tech Workshop bitch !!!
gone but not forgotten
EOS
With the ignition on or off, so if i was driving along and wanted to open my windows i couldn't unless i opened my door.
Well replace fuse 17 then.EOS wrote:With the ignition on or off, so if i was driving along and wanted to open my windows i couldn't unless i opened my door.
fowler
- Boost Junkie
or check for earth faults on dooor connection pins please inform us after brian's suggestion
You're not reading the OP right. They work with the door open, so nothing to do with door pins etc.fowler wrote:or check for earth faults on dooor connection pins please inform us after brian's suggestion
fowler
- Boost Junkie
sorry to early what about the earth for the fuse box from the starter for k7 and all that .
i had the same promlem windows would only work when door was open
and the fault was with the mentioned earth
EOS
cheers guys will check these when i get back home later. If it was the earth to the fuse box surely other things would ahve stopped working properly? What else wouldn't work that i could check?
Yes, but one step at a time - otherwise you end up introducing new faults on top of the existing faults.fowler wrote:sorry to early what about the earth for the fuse box from the starter for k7 and all that .
Roof/windows are on relay K5, mirrors and heater are on K7. A starter motor fault will put out all of these.
hammoj28
Yeah i had this ages ago on my old e30. Was a bit embarrasing going down the road at 70 and having to get the passenger to open the door so we could put the window up!lol Replaced the fuse and it worked.
24v tech2
lentec
- Boost Junkie
I had same problem after changing engine loom.
Think i solved it by adding a link wire in the glovebox?!?
Cant remember what pins it was but if you still havnt sorted it i can check.
Also im only round the corner to eastwood
EOS
Right got home and had a better check this time, wasn't fuse 17 and my electric mirrors are out and the heater fan, so guessing its that starter motor fault someone mentioned earlier. So whats the fix and what should i be looking at? Cheers
@lentec thats cool, what E30 you got seen a few nice ones around eastwood way, makes me want to get mine on the road even quicker
fowler
- Boost Junkie
PM me you email address and i will send you some wiring diagrams
lentec
- Boost Junkie
When i said round the corner ment rochford.
Mine is the beaton up burgundy one with a supercharger!! Cant miss it
EOS
Was it in rochford tyres the other day?
Can't give an accurate diagnosis if I don't get accurate symptoms!!EOS wrote:Right got home and had a better check this time, wasn't fuse 17 and my electric mirrors are out and the heater fan, so guessing its that starter motor fault someone mentioned earlier. So whats the fix and what should i be looking at?
There is a green black wire which goes to the smallest terminal on the starter motor. It earths the neg. end of the unloader relay coils, K5 and K7, except when the starter is used.
Check that it is firmly connected and not corroded. If this seems OK, remove it from the motor, earth it, and try the fan/mirrors/windows.
EOS
Cheers brian, wasn't really looking at the window problem till later was sorting out the central locking and noticed the window only opened when the door was open so just thought i'd ask if it was a common fault. Cheers for the advice and when i get back to it tomorrow will be checking this wire. Makes sense i might have knocked it off cause i was having a fiddle under there the other day
I have the M50 engine in mine at the moment would it still be a green and black wire that im looking for?
EOS
Ignore my last question about the green and black wire im been a bit simple today
??? Seems a sensible question. Yes, same arrangement on the M50, assuming it was connected when the conversion was done.EOS wrote:Ignore my last question about the green and black wire im been a bit simple today
lentec
- Boost Junkie
Probably was.EOS wrote:Was it in rochford tyres the other day?
EOS
Well sorted it this weekend the black ang green wire going into the C101? Connector was broken, so resoldered it and check the others alls well now.
Thanks for the help and advise guys.
