basicaly, i ripped it out of a car today and ive got these two stubs, one black and one grey, i have a check computer and was wondering if i can join it in there, or do i need to run extended wires to one of the interior lights, and which wires do i hook up to ?
bit confused here lads
wiring in a map mirror
johnono
Davenotouring
Hi mate,
You can wire it into the check computer.....but make sure you get the correct wires cos there are a couple of the green and violet ones.
See this guide for more info.
http://e30.bmwdiy.info/lighted-mirror/index.html
BMW 328i Cab - Daily Slag
Simon
I've wired mine into the electric sunroof, if you leave the light switched on, it comes on when you open the door too
johnono
top banana!
ill give it a bash
ill give it a bash
johnono
yep good stuff, it can easily be done, now.. which wire is which, i dont have a multim.
the black one is earth?
and the grey/black is live?
dont want to fry this baby or worse.. so whats the call dudes?
