braking problem
jcjdavis1
Sun Jul 02, 2006 12:18 pm
Hi All need some help.
Was pulling into driveway when brakes went soft,managed to stop before hitting wifes beemer.[more worried about mine].
I still have brakes but they do not feel right,and when I press the pedal I hear a hissing noise from the area behind glovebox.No fluid leaking as brake resevoir full. :(
chu346
Sun Jul 02, 2006 4:02 pm
Could that be a servo leak?
WillG
Sun Jul 02, 2006 4:09 pm
Yeah will be vacuum leak on servo check the pipe going to it from manifold and put hand around area and try feel where its sucking from, when you say they went soft it sounds like pedal went soft but you mean its just brakes arent working very well.
Sun Jul 02, 2006 6:00 pm
WillG wrote:Yeah will be vacuum leak on servo check the pipe going to it from manifold and put hand around area and try feel where its sucking from, when you say they went soft it sounds like pedal went soft but you mean its just brakes aren't working very well.
That makes more sense than the OP. Only thing I could think of was one circuit had failed, but that would have leaked fluid.
jcjdavis1
Sun Jul 02, 2006 6:14 pm
Just in from work,get fed then have a look. Thanks
jcjdavis1
Sun Jul 02, 2006 7:15 pm
Had a try of your ideas but no sign of leak,brakes work but not 100%.
When you pump pedal sounds like bicycle pump[wifes words]
rossco
Sun Jul 02, 2006 7:26 pm
i also have this problem but have not had time to look at it properly
it sounds like air being blown every time you press the brake pedal
the servo seems to work according to a mechanic friend ,who may be no good, but he told me to hold the brakes down then start car and pedal goes down which means the servo is working ,can anyone confirm this test is true?
if you do find the cause please post so i can check ,thanks
jcjdavis1
Sun Jul 02, 2006 7:55 pm
I have tried all the tests in the Haynes manual re the servo and all seems well.I will take car to work tomorrow and see if the mechanic has an idea.
woodysjw
Sun Jul 02, 2006 10:10 pm
I also have this problem too
796 - 1989 Motorsport Edition
rossco
Mon Jul 03, 2006 5:46 pm
well thats a few of us waiting to have an accident!
jcjdavis1
Mon Jul 03, 2006 8:25 pm
I have been under, over and inside the car and cannot find anything wrong anywhere,the servo is working,the master cylender does not leak,all brake pipes are sound no leaks or damp spots anywhere.I went for a drive and did several emergency stops hoping the master cylender would fail,nothing.mechanic went underneath and had a look and found nothing except n/s shocker leaking[more money].Opinion amongst work mates is feet got trapped when appling brakes/clutch.[wearing new doc martins].So hopefully nothing amiss but will keep an eye on the situation.
PS feeling rather stupid after panic. :oops:
Mon Jul 03, 2006 8:36 pm
Wonder if something could have got caught up on a brake disc and pushed a pad back into the caliper?
jcjdavis1
Mon Jul 03, 2006 8:47 pm
I am not busy at work tomorrow so maybe take front wheels off and have a look at brakes.
PS Still haven't sussed how to post a picture any body any ideas. :?
