hi
does anyone know will a z3 m lsd fit in a e30 as i need a 3.15 or 3.25 lsd i know that is what the m3 uses but thought z3m may be stronger
thanks ross
z3m coupe diff
Gwynleym10
It will fit because basically it is an e30 diff! Only difference is the back plate which has extended cooling fins for er better cooling....
You can just put the back plat on any old large case diff, should save some wear, they also look pretty
buster
ive got a z3m diff plate on my lsd so id say yes it should fit.
heres some pics.
heres some pics.
