325 clutch in a 320i - probably another one for Brian!
Dr Firefly
- E30 Zone Doctor
Will a 325 clutch fit in a 320i that still has its standard engine and standard gearbox?
Dr Firefly
- E30 Zone Doctor
Anyone got any ideas? Just need a yes or no answer. Anyone tried it?
Ant
- Retired Team Member
Short answer is yes, should bolt to the fly without issue fella.
Gerboxes are almost identical save for the ratios contained within
Email FTW
gareth
do you need one? if so i have a 2.5 fly and clutch lurking...
WerkdE30
when i converted my 320i to manual i used a 325i gearbox and clutch. it is fine part from the 4.4 diff which is annoying the hell outta me. i was told there are 2 different flywheels but i have no idea if this is true or whether which one u have will make a difference.
