I modified my wiring loom on my 1990 318is (you can see where this is going
Now when I bolted it all back together my rev counter (+ economy meter) no longer works (but everything else does).
I tried a different cluster and that didn't make any difference so I have obviously balsed something up. I have also checked fuses 10 & 21 and they are fine.
Now I see a lot about the black wire on the C101 connector. Just to be sure is the C101 connector the big multiplug by the fusebox in the engine bay (i.e. the one that you plug the service reset tools into etc) or is it somewhere else?
Also what about the white multiplug just by where the main loom enters the car (inside the car). Would this have anything to do with it?
What wires can I get a voltmeter onto to check where the signal for engine speed is reaching and what sort of readings should I be expecting. I believe engine speed comes from Pin #74 (off the top of my head) on the ECU but whats an easy way to test this (and diagnose which pin is which)
I downloaded some wiring diagrams but didn't know where to start really.
