Hi Zoners,
I have a 320i SE that has done 103,000 miles. Is it worth thinking about a rebuild or overhaul? I want to keep the 320 for a long time.
The engine has the ticking sound whilst warm which I have been told is the injectors. What do you suggest, i.e new tappets, piston rings, injectors etc and how much do you think I might be looking at? I live in the greater London /Essex area.
Engine rebuild or overhaul 320iSE
eldarvanyar
fowler
- Boost Junkie
throw a 2.5 in it the 320 is bit of a rubbish engine TBH
get extra 50 horese for a not of lot of work
EX A-Tech Workshop bitch !!!
gone but not forgotten
- Homo Hair
if your gonna rebuild stick a 2.5 in.. 2.0 is a waste of time in the long haul
ticking is a normal thing, any tapping is the tappets which arent difficult to adjust, 103k is barely run in tho
ste
Treat this engine properly, and when its done three times this it might benefit from a rebuild.eldarvanyar wrote:I have a 320i SE that has done 103,000 miles. Is it worth thinking about a rebuild or overhaul?.
It's NOT a Ford.
eldarvanyar
Hi Guys, thanks for all the info, I'm not sure about doing an engine transplant just yet, the engine has been well loooked after as you say this is not a Ford.
Is the 2.0L M20 considered a bad engine then, if so what's wrong with it ? To be honest I am not into going really fast anymore, I have done all my speeding thrills (i think) and there are to many speed cameras now. I am more into keeping the E30 going as a future classic, not to say that I am not open to some subtle mods. If a rebuild is not necessary maybe I will just sort out the tappets. Still welcome any of your learned knowledge.
keith52
i've owned a few 320s and compared to a 325 they're gutless , but i've never head any issues with overheating /headgasket failures , nice smooth engine but low on economy but as Brian indicated looked after & it will serve you well for a few more miles yet. Upgrade the throttle body to a 325 and that will improve the driving experience without altering the originality of the car too much
ste
My experience of the 2.0l M20 compared to the 2.5l is that the 2.0l is gutless, it uses more fuel and costs the same to insure.
I honestly can't think of 1 good reason to have a 2.0l over a 2.5l.
If anything the 2.0l makes a slightly sweeter noise.
Anyone got a real justification for the 2.0l?
eldarvanyar
Is the 325 more economical than the 320? How can that be as the 325 is bigger and more poweful.
I had an ecotech valve put on due to the poor economy. I was getting 15-18 miles around town and 25 on a run. The ecotech gave me an extra 3 miles on both. What does the 325 give? Is the 320 more reliable ? An engine swap is sounding the way to go.
320i was introduced for tax reasons in Germany. Not applicable in the UK, but, apparently still a very valid reason in Eire, and probably a few other countries as well.
320i drinks as much fuel as a 325, but doesn't deliver the performance. It's only a little faster than a 318i, but a lot smoother and nicer sounding, and doesn't seem to crack heads quite as often as the 325i.
If you can live with the fuel consumption, there's nothing wrong with a 320i, BUT don't waste time and money trying to tune it.
