lsd
mark320i
just bought a 3:64 lsd, how hard is this to fit any1 know?
Chris-W
Doddle.
4 x 17mm bnuts attaching the prop shaft, 6 x 8mm hex bolts holding each drive shaft on, then 4 x 19mm bolts holding the diff to the rear beam, plus a 19mm bolt/nut holding the diff to the shell.
Need a jack or large block of wood to support the diff coming down and going back up.
mark320i
cheers mate thats great
