Post
Sun Jun 18, 2006 11:33 am
Should be fitted dry, but you should put a small amount of silicone/gasket sealer across the join between the block and the timing cover/rear oil seal carrier. If you don't do this it will leak slightly.
It's also very important to only do the bolts up to the correct torque. These should be 10Nm and no more. If you are doing it by feel then you will most likely over tighten them. 10Nm feels like naff all, but it is correct.
Cheers,
Ian.
