Swapping the interior
NIX
Post Mon Jun 12, 2006 11:05 pm
I'm sure this has been asked before but hey.
Hope to get a leather recaro set and get rid of my sorry comfort cloth.
Just wanted to make sure its a job that can be done by a relative novice. I can see the rear seats being an easy job but what tools will I need for the fronts? How easy is it? Key stages? Estimated completion time?
Any info as always is appreciated!
Cheers in advance!
Nick
Post Mon Jun 12, 2006 11:09 pm
Only tool needed for the rears is a 10mm socket, and only tool for the fronts is a 17mm socket. Dead easy. Mind the paintwork when you lift the fronts in and out.
NIX
Post Mon Jun 12, 2006 11:22 pm
Thanks mate!
Didn't think I needed any sockets for the rears? I'm sure I've taken them out before but then again my memory is pretty shoddy these days.
I'm sure I have 10mm and 17mm sockets anyway........i think?!
Anything else I should look out for apart from the paintwork?
Thanks!
Nick
Post Tue Jun 13, 2006 12:20 am
Bolts art the rear of the front seats go through to the outside, so might be rusty.
Shoulb be a 10mm self tapper each side of the rear seat back, low down, and hidden by a loose flap of vinyl.
NIX
Post Tue Jun 13, 2006 1:36 pm
Nice one mate, I'll bare that in mind.
So with regard to the bolts that go through to the outside, will i have to jack the car up to get a wrench on the other side or will they just drop out? although if thats the case i take it i'd have to jack the car up anyways to get the bolts back in once the new seats are in?
Post Tue Jun 13, 2006 7:13 pm
No need to get under the car. The nuts are welded to the body, and the bolt heads are inside the car. It's just the bottom end of the threads that are exposed to the elements. Reassemble with copper grease.
NIX
Post Tue Jun 13, 2006 7:36 pm
ahhhh. I get ya!
Thanks very much mate. As always in this section, you're a great help!
Cheers,
Nick
