323i vacuum hose
Rodderz
Sun Jun 11, 2006 1:12 pm
Hi,has anyone in the southampton area have a 323i car that I could look at? I have an old E30 with the 2.3 engine and one of the vacuum hoses blanked off,and I need to know where it should lead to so I can get the car running!
Rod
07901 715575
Boots_Walker
Wed Jun 14, 2006 9:09 am
rodderz, where is the other end of the hose connected to - or what part of the engine/manifold has been blocked off (not sure exactly which you meant)
Wed Jun 14, 2006 9:18 am
Any E30 engine will run OK with a blanked off vacuun connection.
Whatever the vacumn connection is for. it's to feed something external to the engine, like a servo, or emissions gear.
My guess (based on absolurely nothing) is the servo connections have been simplified and this is the spare connection of the big air hose.
Rodderz
Mon Jun 19, 2006 6:28 pm
The hose that is missing is the one in the middle that is blanked off with black insulating tape!!! Any help guys???
k130
Fri Jun 23, 2006 8:11 pm
Hi mate
I just had a look at my '83 323i the hose thats missing is not a hose, its where the cold start injector should be. There should be a fuel pipe leading up to it and a blue 2pin injector connector (and injector, obviously).
Do you have cold start problems??
dazleeds
old skool raver
old skool raver
Fri Jun 23, 2006 8:19 pm
Rodderz wrote:The hose that is missing is the one in the middle that is blanked off with black insulating tape!!! Any help guys???
heres a pic of my old 323 as you see it has a red blanking cap as have several e30 323i that i have owned
www.oldskoolfantasy.co.uk
k130
Fri Jun 23, 2006 8:29 pm
sorry cant put up a picture but see this link:
http://www.realoem.com/bmw/showparts.do ... g=11&fg=40
Its Item 7, mine looks just like this.
Fri Jun 23, 2006 10:24 pm
Pure guess work, since I've never seen a 323i, and know nothing about them, but cold start valves were only used on early fuel injection systems. As ECUs became more sophisticated, the cold start injector was deleted and replaced by the ECU increasing the duty cycle of the normal injectors instead.
This could be the reason that some 323s have them, and some are blanked.
k130
Sat Jun 24, 2006 10:40 am
thats right.
My 323i is an '83 model, I think by '85 the start valve was done away with. Whenever I go into GSF with year and model they keep asking me if its an E21!
Sat Jun 24, 2006 10:52 am
In that case, Mr Rodderz, if you post up the number on your ECU, someone should be able to tell you if your injection system should have the cold start valve or not.
dazleeds
old skool raver
old skool raver
Sat Jun 24, 2006 2:00 pm
dont know if this will help but it may do??
http://www.bba-reman.com/catalogue/Prod ... ategory=62
mine was a c reg and didnt have the cold start
