Another annoying characteristic...a misfire
C33
Post Thu Jun 08, 2006 11:23 pm
Something else I've noticed with my car recently that's starting to get annoying, accellerating away from a junction or roundabout etc, get to about 3k rpm in 3rd gear and I get a momentry stutter, not a flat spot as if the mixture was wrong, but it it feels like the engine misses a signal or something, it's gone in an instant but it's enough to produce a shunt through the drive train.
What's even wierder is if I then slow down and try and replicate it by accellerating through 3rd again nothing happens, I haven't been able to provoke it, it only happens occasionally when I run it through the gears from a junction.
Any ideas?
Regards
Iain
gazza
Post Fri Jun 09, 2006 7:51 pm
what type of engine/car........have you tried to chane the dme relay they are often at fault they overheat and cut the fuel out for a very short time
C33
Post Fri Jun 09, 2006 11:53 pm
Hi, sorry, it's 1989 F plate 318i.
Where is the DME relay hidden?
Regards
Iain
