hELP - Front wheel bearing removal and torque
Partridge
Post Sat Mar 05, 2005 11:54 am
Fitting 325 struts to my 1990 320. Expected the inner bearing to slide off the axle when the hub was removed- wrong!
Do I need a puller/special tool to remove or should I apply force via the lump hammer?
What is the torque for the hub nut on refitting?
Thanks in advance
Andrew
boybimmerm3
Post Sat Mar 05, 2005 2:51 pm
hi m8, just done one this morning too! the inner race of the bearing got stuck on mine too. best thing to do is remove the metal backplate( 3 10mm bolts) if you have not done so and use a chiesel and knock it off, they are not usually hard to knock off. use a new nut if possible and torque to 290nm or 215 lb/ft.
Partridge
Post Sun Mar 06, 2005 11:11 pm
Thanks for that, I had the bearings off, but I needed the torque. That is quite a lot!
