Found this on Ebay, as mine is noisy and needs replacing. Does anybody know if it's OK. The part numbers listed match that on the ETK !
http://cgi.ebay.co.uk/BRAND-NEW-Electri ... dZViewItem
Early Ext Fuel Pump
zaust
- Zone day release
- Location: Somewhere in Hertfordshire , or press Ctrl + W
Noisy high pressure pump on the early two pump system often means the in tank pump has failed.
Both pumps can be replaced by a single later type pump, which fits directly in place of the in tank pump. External pump is just removed and replaced by a piece of high pressure fuel hose.
