e30 325i sport 88 making a kinda ticking noise
Nissar
Post Mon Jun 05, 2006 10:12 pm
Hi all,
ok so basically what is above... it makes a ticking noise in the mornings when first started... but after she gets warm she is fine once i start drivin her.
any suggestions?
Post Mon Jun 05, 2006 10:48 pm
Check the tappet clearances. If they're OK, then it's probably the injectors, or the valve gear just running a bit dry untill the oil gets up there. Doubt if it's anything to worry about.
