i filled the header tank up with fluid but by the morning it had leaked out onto my drive... It appears to be coming from around the bell housing (at the bottom).. Now, am i right in thinking that its proberbly the slave cylinder that has gone? Does the gear box have to come out? If so, any advice on the best way?
heres a picture of where i think its leaking from (if it helps)
http://myspace-391.vo.llnwd.net/00799/1 ... 2391_m.jpg
Theres also another leak, coming from the 'output shaft?' near the rubber coupling on the propshaft. I'm assuming that this doesnt really have much to do with the clutch, but with this in mind, would it make sense to drop the box, and do the clutch and this leak at the same time?
Again, heres a picture of the offending area
http://myspace-476.vo.llnwd.net/00799/6 ... 8476_m.jpg
right, well i think thats all for today
Thanks! Guy.
