rear subframe bushes
ant2
i managed to get the rear beam off but i am stuck with the ally bit of the subframe stuck onto the bolt that holds the beam on, is there an easy way to get the but of ally off
Hammer
ant2
you cant get to them on the car, thats the problem
If youve got the beam off there should be plenty of room
Martinaston
Put the nut back on the end of the drift pin to protect the thread and bang it up through the chassie with a hammer, lift the back seat to allow the pins to rise up.
Then bang the sleeve back and forth to loosen it, not too far or you'll damage the hole it sits in.
It's normally just rust holding it in.
ant2
ah i managed it with a 2 meter scaffold pole and a large stiltson, that wasnt a fun job
Better than a hammer though
Why couldnt they just grease them up before fitting in the first place
Chris-W
You didn't turn them did you?ant2 wrote:ah i managed it with a 2 meter scaffold pole and a large stiltson, that wasnt a fun job
ant2
yeh just abit untill they came loose
craigieeb
M50 Turbo!!!
I shall say no more
ant2
the bolts are still well in, its the ally but of the bush that turned
craigieeb
ahhhhhh, right the best way to get the bolts out is to is to have the frame back up, and give them a GOOD clatter with a hammer as described above,
to get the rubber, and the center ally bit out i found just attacking the whole rubber bush with a drill from underneeth worked quite good
(ish)
(ish)
M50 Turbo!!!
I shall say no more
Just removed a rear beam tonight before I came in.
Didn't want to come off, but twenty minutes with a blowlamp, a four foot pry bar and a four pound lump hammer it all surrendered.
Chris-W
Ah, the Chilean route to acquiescence!Brianmoooore wrote: twenty minutes with a blowlamp, a four foot pry bar and a four pound lump hammer it all surrendered.
Wanted to get indoors to watch Fifth Gear.Chris-W wrote:Ah, the Chilean route to acquiescence!Brianmoooore wrote: twenty minutes with a blowlamp, a four foot pry bar and a four pound lump hammer it all surrendered.
craigieeb
D'OH!Brianmoooore wrote:Wanted to get indoors to watch Fifth Gear.
M50 Turbo!!!
I shall say no more
