just read the other post and it doesnt quite answer my situation, i need to remove the ignition barrel to replace it with a non (attempted theft) one. but i cant get my key in to get it to P1 to remove it with pin!!
any ideas?
removing ignition barrel - WITH a complication!
Well you can either go at the key slot with a good drill, or drill the housing from underneath just below where the locking tab locates and punch it out.
smithy318i
Edit:
you can try and remove the outer cover and insert.
however there is a chance you will break the lock surround in the process.
ollielsd
These cars are supposed to be thief proof, and you are effectively wanting to do what is necessary to nick it. It's not meant to be easy!
ollielsd
lol - yeh i realise this brian. il just live with using screwdriver for now
