Can be added easily enough, if you get ALL the bits from a scrapper.
Need rack, steering lower coupling, pipes resevoir and bracket, pump and correct bracket for an M20, and pulley and bolts to fix in front of existing crank pulley.
When you find a rack, check that there is no steering fluid inside the rack end bellows.
