Guys,if i use 3.5 injectors do i need to get some sort of adaptor so the OBC still calculates MPG etc...Also for the MS guys if i went the MS route and kept the Motronic powered up would the above still work along witn Tach etc??
thks
~~OBC/Megasquirt question~~
Ant
- Retired Team Member
Hi mate, if you leave the motronic in the loop , the OBC etc wil still function, the MPG will be miles out though M8
the yellows with MS are a good call.
Email FTW
JAMZ
Hey Ant, howz you m8?
You say Yellows? would THEY work with the MS setup then and calculate MPG? or are you just recomending them and OBC is basicaly a glorified clock from now on once the 3.5 injectors are in..
Bascialy the 3.5 injectors will be in for the meantime till i can fund something else m8..but if yer saying the yellows WILL work with the OBC then that will defo be the next port of call
thks dude
thks dude
