any one ever done it? i quite fancy the challenge and after an inital look they're are similar enough to warrant a further look.
parts and or fabrication wont be an issue, just wondered if anyones look into it - or even used the diff??
subaru rear suspension
ollielsd
just i think the e30 rear suspension is basically flawed and the impreza rear end wud be a great starting point for an (almost) infinitely adjustable rear end for track use
Agreed that the E30 rear suspension is not the worlds most sophisticated, but you said the Subaru suspension was similar(ly flawed).
ollielsd
yeh lol, i meant similar in terms of mounting etc, not design. it uses a cross beam with two mounts similar to the BM and a rear mounting for dif, sus links etc, im sure the suby sus cud be mated to the BM mounting points
Andy335Touring
Post a picture or diagram of the scuby suspension as you might help people to help you if they know what it looks like ?ollielsd wrote:yeh lol, i meant similar in terms of mounting etc, not design. it uses a cross beam with two mounts similar to the BM and a rear mounting for dif, sus links etc, im sure the suby sus cud be mated to the BM mounting points
ollielsd
good point mate - il try and get one sorted
