The imobiliser on the touring is a piece of shit, sometimes it works some times it dont !
Its the audio type jack one...
How can i bypass this ?
Help ! ! I cant move me car.
Imobiliser Help ! ! !
Regularly rip these pieces of junk out.
Remove the cover above the glove box. Find a white two pin socket with two green wires. Unplug whatever is connected to it, and have a search around the area for a matching plug with a small loop[ of green wire taped to the loom. If you find this, then untape it and plug it in.
If you can't find it, cut the wires of the plug you removed about two inches from the plug, solder the ends together and insulate properly, preferably with heat shrink tubing.
m-dtech
- Unapproved Trader caution
what i have done is cut open the key fob taken out the resistor, soldered the resistor to a push switch and mounted on a switch blanking plate.. then attached the wires.
the jack wasnt making a connection.
still kinda got an immobiliser lol
like so;
like so;
