Problem itting mongoose exhuast to down pipe
Nathan
Post Mon May 29, 2006 4:10 pm
I'm currently trying to fit a mongoose exhaust to my 325, the only problem is that the mongoose exhaust has a flange with 2 bolt holes on each pipe, where as my down pipes have flanges which have a 3 hole flange, now the old exhaust was a bit of a lash up of seemingly random bits and pieces.
So is the down pipe off another E30 or am I going to have to just start cutting it up to get it to fit?
tickle
Post Wed May 31, 2006 1:42 am
try this site
http://www.realoem.com
it should show what should be there :D
Cars and girlfriends have alot in common.
They both make you angry+ make you cry, bleed your wallet + moan when they are old.
But at least the car makes sense!
Post Wed May 31, 2006 9:45 am
You can get a brand new downpipe from Euro Car Parts for under £30.
Not worth chopping IMO.
Im pretty sure the later cars had the 2 hole flanges compared to the early cars 3
