I can't get the back part of the back seats out, ali can see is a black meatl plate with no screws or anything... how does this come out?
Touring rear seat removal...help needed...
oze30
I think on the rhs as you look at it.. or either side.. there's a little metal catch that you depress with a screw driver, then the whole bac king slides out.. I think.. but don't quote me. It should be on the inch( ?) wide metal strip that bolts to the floor.
Widge
Depress the metal thing that unlocks the metal bit from the sides as if you were putting the back seat down. Then with the metal bit at 45 degrees push it to one side or the other which ever way it will go and one side of the bottom will pop out . You can then take the other side out and that seat back will lift out. Then do the same with the other one.
taxidriver
thanks guys, will give it go
325i Touring
As oze30 says, but there should be a catch each side.taxidriver wrote:thanks guys, will give it go
