hood shelf not locking down!!
garymillscab
just wondering if there is any way i can get my hood shelfto lock down on my 1990 cab it has electric hood but this doesent work .is there anyway of just getting hood shelf to lock down without getting hood motor working as bit strapped for cash and the summers coming.
DaveD
- E30Zone Wiki Specialist
if you want to send me an email address i will send you instructions in a pdf
garymillscab
pm sent cheers mate
DaveD
no pm yet
chu346
You could just plug the motor in with the flap pushed down and it will hold.
garymillscab
The hood motor seems to turn but there is no movement from anything else !
garyrmills2000@yaho.co.uk cheers
chu346
I meant fold the roof down, then push the flap down, then push the flap motor into position. Quick 'n' easy fix.
gazza
when the hood flap motor turns it picks up the locking bracket that is behind it, which in turn pulls the 2 cables that in turn close the 2 claws that lock the cover down. on mine the arm was bent (towards the front of the car)by just a few mm and as a result as it turned it could locate with the arm behind it enough to pull the cables. take the arm out (a single allen key i think)and lever it out check that it is at a good right angle and not bent beyond 90 degrees if so put it in a vice and return it to 90 degrees and refit it ....i hope this helps its not very easy without pics ....a tip dont adjust the 2 cables as when it operates correctly they will be to short and at the very least you will snap the cables
Quaser
i put in a manual switch for the back locking mechanism
